Well that could have been worse
Mike_Sheppard
Member Posts: 696
I don’t have any more details. Just thought you guys would get a kick out of the relief valve... Was found by a co-worker. Was brand new.
The two lines coming down into the relief valve tapping are returns from zones....
Never stop learning.
Once again- you can't fix stupid!All Steamed Up, Inc.
Consulting2 -
I would not want to be the one who left that relief valve down stream of a shutoff.valve! Sorta like painting a bullseye on your back.
Yours, Larry0 -
> Yours, Larry
Not only that, it’s also installed backwards!Never stop learning.0 -
The mind boggles.0
With regard to the relief valve, it looks like they went with the lowest bidder, or was it the owner's brother in law that's kind of handy???
What's left of the boiler and burner look like they may have been installed by a professional. Maybe not the very best installation, but probably acceptable. I'm guessing the installer was long gone when that relief valve was installed?0 -
Wow. So did some other control fail?NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
Ouch0
To my knowledge, this was a brand new boiler. They had just installed it and started it up for the winter. I believe it was installed like this from day 1.Never stop learning.0
If only it were that simple. Stupid usually "fixes" innocent people, and not in a good way.Larry Weingarten said:But, if you’re not careful, stupid will fix you?
Yours, Larry
For the benefit of non-pros reading this- not sure what type of building this is in, but if the boiler had exploded worse than it did, it could have taken the whole building with it, along with everyone inside.All Steamed Up, Inc.
Consulting0 -
In that case, if you haven't already done so, you need to go over the whole installation. No telling what else they did that was stupid, and you were the last one to touch it.Mike_Sheppard said:To my knowledge, this was a brand new boiler. They had just installed it and started it up for the winter. I believe it was installed like this from day 1.
Consulting1 -
Wow, I just looked a little closer at the picture of the Powerflame burner. Notice the shutoff valve on the small pilot pressure regulator with the copper compression fitting. You are never supposed to install a shutoff valve on the vent of a gas pressure regulator. Must have been same guy that piped the boiler relief valve.
I also noticed yet another shutoff valve that is piped into one of the 1/4 inch tapping on the bottom of the Honeywell gas valve, wonder where that goes?
I realize all contractors make mistakes, but this one is getting more interesting as the story develops. After further review, I take back my earlier comment about it looking like a professional install. I hope no one got hurt!0 -
Lucky that shutoff valve is closed off. That way it protects the pressure relief valve (installed backwards) from the rest of the system. Gawd!
With the welded steel pipe, and a boiler big enough to warrant that size Power Flame, I'm guessing this is at least a light commercial system. There are many things wrong here! Wow! While it is amusing now, that could have been catastrophic for sure.
That really is the definition of stupid. Whoever did that should not be in the heating business. Valved relief....dumb, backwards relief........Stupid! Compressions on gas line....against code, valved ragulayor vent......Stupid! Returns T'd into relief port is just weird.
I dont use the word stupid lightly when applied to people.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
@Mike_Sheppard , I sure hope the licensing authorities get involved..............All Steamed Up, Inc.
Consulting1 -
LOL! I did not even notice the valve on the vent. Wow!Never stop learning.1 -
> @RayWohlfarth said:
> @Mike_Sheppard Can I use that pic for my classes
Sure!
I want to see it in your next book! LolNever stop learning.0 -
This was an apartment building.
The boiler is gone by now. A new boiler with a proper install and permits was done.
The section blew out because the relief valve was isolated. Those sections are rated for 80 psi. I’m sure it saw well above 80 psi.
Nothing the controls could have done about it, it was a water boiler. No pressuretrols.Never stop learning.0 -
Mike, was there no expansion tank on this system, or was that valved off too? Aquastats jumped too (wonder if they even installed them)?0
@ScottSecor I am not sure. A co-worker was the one who found this and sent me pictures.Never stop learning.0
@ScottSecor
Your right about the valve on the pilot regulator vent, I haden't noticed that. The other 1/4" coming of the bottom of the Honeywell valve is for checking gas pressure or it is sometimes used for a low gas pressure switch, although I don't like coming off the bottom for a safety control0 -
Every once in a while we come across something like this.
Can't help but wonder how many are installed in such a dangerous way. This is maybe the sixth boiler I have either seen in a picture or come across first hand.
Makes me wonder, are installations getting worse or better? Is the qualified tech. surely becoming extinct?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
