Water heater
MikeJ
Member Posts: 103
I keep picturing the guy saying "that aint goin' no wheres" after putting on the clamp0
Being a techie and able to do it right I always thought city inspectors were just money grabbing profit center for the city. Now I see why they exist.
Problem is they can't stop this guy, it happened.0 -
That gas line would not pass here.0
What's wrong with that? Looks fine to me.
Some people belong in jail.
Lucky the place has not burned to the ground0 -
She is entitled to a full refund and apply that money towards someone who will do it correctly.
And some people get mad about codes and inspectors.0 -
Nice sharkbite water connectior!
Did it draft At all?MikeJ said:Was at this house yesterday working on the furnace. She just had a water heater installed by a painter/handyman.
Shut off the water heater and the gas, told her not to use it till you get a license plumber out here. Old water heater was a power draft. Very dangerous
Were his initials RTH? He was so proud he signed it0
manslaughter by proxy !0
Would have been better off not connecting the flue at all. I still see a few water heaters sitting in a corner of a basement running without a flue connector at all.
The thought that someone actually connected PVC to that thing is beyond scary, likely no draught saved the PVC from melting altogether.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
The reason we got the service call for the furnace, this same guy also installed a Nest stat, she went to use the furnace and the furnace would not come on, he had wire the stat up wrong.
Its a good thing he did wire it up wrong,
Nice one flat_twin
Not sure if it was drafting did not check, flue runs to the roof.
3 story condo
Water heater is in a room in the garage, so yes better off leaving it unhooked.
The killer now is all the PVC has to be replaced... or should be... all 3 stories of it.0
Sure would like to know what the end result of all this will be.0
Oh....I hope you are joking within the vein of the conversation.
I wouldn't want someone who doesn't know what they are doing to read that🙄 and put number 14 wire on a 30amp breaker .mikeg2015 said:
Usually its to install an electric heater if there’s an breaker panel nearby. Probably use 14ga on a 30A circuit for that too.Intplm. said:Sure would like to know what the end result of all this will be.
Yes... it was meant that just like the plastic pipe for a atmospheric WH here, there are probably several units out there with 30A breakers and undersized 14ga NM-B wire instead of 10 gauge.
Replaced a furnace last week and found 30AMP single pole on 12 gauge. Worse, the furnace calls for 15A Max fuse to protect it’s internal wiring. You can use a fused switch at the unit or just a regular light switch but change the breaker. Breaker costs $6. Easy to swap out. (Pssst.... dont tell anyone though, I’m not a master electrician.)0 -
- 119 Chimneys & Flues
- 76 Pipe Deterioration
