Hot to circulator pump, cold after. Replace pump or something else?
Hi there, curious if it could be something else or replace pump? If replace easy to do on own? Drain system?
Thanks everyone
  • Ironman
    Ironman Member Posts: 7,766
    Could very well be the pump(s). They are not supposed to be mounted like that. They must be mounted with the motor horizontal. The bearings are water lubricated and they'll become dry by air being trapped at the top when mounted vertically (shaft up). If mounted shaft down, debris and sediment will ruin the bearings.
    They gotta be horizontal.
    Bob Boan
    JellisRich_49
    pecmsg Member Posts: 6,535
    Actually that's allowed if over 20#'s operating pressure but it is frowned upon.
    Jellis
  • Alan Welch
    Alan Welch Member Posts: 270
    Yes, it could be something else. Do you have electric power at the circulator?
  • rick in Alaska
    rick in Alaska Member Posts: 1,504
    Is there enough pressure in the system, typically 12 psi, and does the line possibly have air in it?
    Rick
  • Ironman
    edited March 2019
    And how many residential systems have 20 psi static pressure?
    And Taco is the only one that allows it under those conditions.
    Bob Boan
    Not disputing or arguing that point in any shape of firm.
    Ironman
