Single Riser with Drop Header Question
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
I found the smallest Peerless 603 (at my local supply house, Wallington!) available for not that much more than the smallest WM so now I'm leaning toward Peerless for this summer's replacement. I will be able to harvest my LWCO from my Utica I think.
@ethicalpaul boiler comes with a new LWCOCost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
And I've heard great things about it, too!!!Charlie from wmass said:@ethicalpaul boiler comes with a new LWCO
They are fine. Mountain out of a molehill.Cost is what you spend , value is what you get.
cell # 413-841-6726
Thanks @Charlie from wmass I am open to that idea being a skeptical person generally!
I would leave it on to try it out, but I think I saw someone say they are 120vNJ Steam Homeowner.
24 volt on gas 120 0n oil or gas power burnerCost is what you spend , value is what you get.
cell # 413-841-6726
Yes still in the game never left .Still doing the same stuff I hope by 75 I’m still on the green side of the turf and will most likely still be doing able to work . I glad to see ur still on the sun side side peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating1
