Favorite brand of O2 barrier pex for radiant concrete slabs, and why?
Gordy
Member Posts: 9,546
Yes, Uponor is great and seems to have a tighter bending radius than others. We also use Mr. PEX when the budget is less flexible. Both are PEX A and we use the Uponor fittings and rings.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Uponer or Rahua. Both Pex-A and both have stood the test of time."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I will gather everyone uses expansion fittings verses crimp?0
Rehau if we use CreteHeat; Roth PAP if it gets zip tied to the mesh. With under floor plates, Rehau or Roth PERT. Rehau f2080 expansion fittings.Bob Boan
I'll be "that guy" here. Buried in concrete, I almost always use Everhot tubing; really don't see a benefit to pex-A when it's buried in a slab. Walls, ceilings, and overlays get HePex. Underfloor I've really been liking PE-RT from Oil Creek for the flexibilty but otherwise HePex. Don't own an expansion tool and don't want one, the Viega style SS crimp collars and brass fittings have never done me wrong0
I've used uponor. Started using it a long time ago when it was first introduced into this country. (Was called wirsbo back then). Found it to be the strongest, lasing it into walls and tight spaces. It can stand up to rough handling in the tightest places. The best pipe as far as I have seen.
Oddly I'm not a big fan of the connection process. Expand the pipe.......then how long before you can turn on the water???
With crimp connections you turn the water on right away.
And you can crimp uponor. Uponor doesn't endorse crimping there pipe however, as far as I know.?0 -
It seems most of the people around me are using the Viega PEX ... My guess because Viega has such a big presence with domestic plumbing (they do make a nice manifold) ... and it's the less expensive B.
Who sells Mr. Pex now? Supplyhouse.com not showing tubing? Mr. is a Pex A correct? I think would be my choice for doing my 3/8 job.
For slabs I guess the more flex of the A has little benefit ..0 -
I've been buying Mr.Pex from a local wholesaler. Last box said "Made in Sweden" on it. I avoid anything which is not made in North America or Europe. If it says the "C" word on it, I pass.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Uponor endorses crimp connections, it's listed on the side of the pipe, if I'm remembering correctly. The expansion connection process doesn't take long before you can pressure it up. I have connections flowing water within 30 seconds of attaching the fittings in most cases.Intplm. said:I've used uponor. Started using it a long time ago when it was first introduced into this country. (Was called wirsbo back then). Found it to be the strongest, lasing it into walls and tight spaces. It can stand up to rough handling in the tightest places. The best pipe as far as I have seen.
And you can crimp uponor. Uponor doesn't endorse crimping there pipe however, as far as I know.?You can have it good, fast or cheap. Pick two1 -
@Canucker Thank you for that. I will double check the writing on the pipe. I like uponor a lot. I use it more than any other. I have been crimping there pipe along time now. I will look into the expansion again. Had a few bad experiences a very long time ago when it first came out that put me off the expansion method.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
