High temperature sump pumps
Steve_210
Member Posts: 664
What is Everybody using for boiler room sump pumps
Installs 2 high temperature in the last week, went back to both jobs yesterday had to pull the pumps and reinstall to get them to work.
Impeller moves freely with a screwdriver I suspect there was some debris there that fell off when we were pulling them out.
Obviously if the boiler is in a pit as both of these are sump pump failure could be disastrous.
Cost is not so much of an issue but would need something that’s very reliable
Bump0
What are they pumping? Just groundwater? Blowdown water? What failed, exactly?0
Actually I think it was just Very hot water what is everybody using for boiler room sump pumps?0
Why do you have water that hot in the sump pit?0
High or low pressure boiler?0
Low pressure mainly steam some Hot water0
Blow down on mechanical low water cut off’s
Water can be very hot0 -
Do two pumps. One installed at the bottom of the pit and another one installed on a couple of blocks for a backup in case the first pump fails.0
I moved and re-installed a Zoeller pump for the same thing last year, to take blow down from a steam boiler. No issues at all. The things been working great for a few years now. Don't know if it is rated for high temp. Looked like a normal sump pump. Just older.0
Think I bought some from Grainger a few years back but you would have to search their. Condensate cooler would be good 120 deg is max to sewer I think0
How much water are they running?0
FYI, I got two Zoeller CI pumps & a lead/lag controller from Supplyhouse.com a few years ago for the building sump at my church, cheaper than I could have build up from parts from the Big Box stores. I can put over 100 GPM out the discharge if necessary now, more than enough to keep up with the entering water service plus enough capacity to deal with any rainfall we've had in the last few decades.
Regarding temperature, the pumps I got are good to 130°, so you'd need to recover some heat (preheat domestic water maybe?) or temper via cold water if you can't guarantee the condensate will be cooler than that.
- 120 Geothermal
