When turn on hot water it is brown
Hello, notice when I turn on the hot water in shower and in the sink the water is brown. I have to continue to run The water then it will run clear. Now sure about the kitchen or other sink in basement, because the lighting not good that I can tell. Help much appreciated. Thank you
What type of piping do you have? Galvanized?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I guess I also should ask if you are on a well and what you know about your water quality.
Galvanized pipe tends to corrode over time. The corrosion is intensified when heat is increased. My guess would be that that is where the brown is coming from.
How old is the house? Has any of the original piping been replaced? Are you experience low pressure in areas?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
If you really have galvanized pipe, that's your problem. Been there, done that. Even have the T shirt. Two solutions: put up with running the water until it clears, or repipe it. The latter shouldn't be that hard, depending on how the house is piped.Br. Jamie, osb
@Jamie Hall running the water it what I will do for now. Is it safe after the brown has gone to use the water to cook with? Would you know?0
You'd be surprised .. I've only in the last two years gotten rid of almost all the galvanized in Cedric's home (there's still about 10 feet left Hard to get to... All put in about 100 years ago.pecmsg said:I would be surprised if galv is on the water supply. After almost 60 years it would have been replaced by now!
Please post picsBr. Jamie, osb
Please post pics
I'm leaning toward the tanks rusting
It all depends on the water. I had a property that made it about 55 years before the rust and water pressure became unbearable.
Albert Einstein0 -
Built in 59" I doubt that it is galvanized. @Acey_A find yourself a magnet and see if it sticks to your water pipes. If it sticks you have galvanized pipe, if not it's probably copper1
Could be galvanized in the street. But probably copper from the street to the house. Heck. I have seen very old water mains made of wood dug up from the street.0
Hello, A few more things to look at are the age of the water heater and whether the anode has ever been changed. If the heater is "old" and the anode has not been changed, the tank could be giving you some rusty water. Also, if there is a recirculation line, you could be getting some backflow through it, carrying rust to the taps.
Yours, Larry1 -
I have a indirect water heater installed 2015, not
sure what a recirculation line is, but I look it up and check. Thank you0 -
- 50 Industry Classes
