When turn on hot water it is brown
Acey_A
Acey_A Member Posts: 49
Hello, notice when I turn on the hot water in shower and in the sink the water is brown. I have to continue to run The water then it will run clear. Now sure about the kitchen or other sink in basement, because the lighting not good that I can tell. Help much appreciated. Thank you
  • Zman
    Zman Member Posts: 7,611
    What type of piping do you have? Galvanized?
    Albert Einstein
  • Acey_A
    @Zman I had to look it up didn’t know what that meant, but yes I do.
  • Zman
    I guess I also should ask if you are on a well and what you know about your water quality.
    Galvanized pipe tends to corrode over time. The corrosion is intensified when heat is increased. My guess would be that that is where the brown is coming from.
    How old is the house? Has any of the original piping been replaced? Are you experience low pressure in areas?
    Albert Einstein
    Acey_A
  • Acey_A
    @Zman I have city water. The House was built in 1959 almost sure original piping and the pressure is fine
    Jamie Hall Member Posts: 27,285
    If you really have galvanized pipe, that's your problem. Been there, done that. Even have the T shirt. Two solutions: put up with running the water until it clears, or repipe it. The latter shouldn't be that hard, depending on how the house is piped.
    Acey_A
  • Acey_A
    @Jamie Hall running the water it what I will do for now. Is it safe after the brown has gone to use the water to cook with? Would you know?
    pecmsg Member Posts: 7,034
    Its only iron, just be careful with the washing machine!
    Acey_A
    I would be surprised if galv is on the water supply. After almost 60 years it would have been replaced by now!
    Please post pics
    Acey_A
  • Acey_A
    @pecmsg what do you mean by washing machine? It could damage it?
    Stain the cloths!
    Acey_A
    Please post pics
    You'd be surprised .. I've only in the last two years gotten rid of almost all the galvanized in Cedric's home (there's still about 10 feet left Hard to get to... All put in about 100 years ago.
    Please post pics
    I didn't say impossible!
    I'm leaning toward the tanks rusting
  • Zman
    It all depends on the water. I had a property that made it about 55 years before the rust and water pressure became unbearable.
    Albert Einstein
    EBEBRATT-Ed Member Posts: 20,116
    Built in 59" I doubt that it is galvanized. @Acey_A find yourself a magnet and see if it sticks to your water pipes. If it sticks you have galvanized pipe, if not it's probably copper
    Acey_A
  • Intplm.
    Intplm. Member Posts: 2,998
    Could be galvanized in the street. But probably copper from the street to the house. Heck. I have seen very old water mains made of wood dug up from the street.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,079
    Hello, A few more things to look at are the age of the water heater and whether the anode has ever been changed. If the heater is "old" and the anode has not been changed, the tank could be giving you some rusty water. Also, if there is a recirculation line, you could be getting some backflow through it, carrying rust to the taps.
    Yours, Larry
    Acey_A
  • Acey_A
    I have a indirect water heater installed 2015, not
    sure what a recirculation line is, but I look it up and check. Thank you
  • Leonard
    Leonard Member Posts: 903
    City water pressure in our 61 year old house was dropping over the years, till finally it was too low. I opened the sinks and listen along pipes. All copper piping but found a steel plug in a copper tee. Rust from plug expanded across the Tee and choked off flow, almost completely.
    Acey_A
