How do I stop the banging in this steam boiler?
Joseph_4
Member Posts: 312
Hello out there, I have a customer who has a green mountain steam boiler which got a leak in it and all the water leaked out a few times. To try to get him over to the summer I got some boiler sodder which the manufacturer green mountain said would be a good idea to put in and they recommend it. I have done this multiple times before and have never had this problem, this is the first time that the water line is jumping a lot and there is water getting into the header and there is a lot a lot of banging and hammering. I did a cleaning of the boiler and flushed it out and didn't really get much leftover sodder and I did a steam cleaning which I don't know if that was ever done when it was installed and i am still getting some vicious banging, how do I stop the pipes from banging? I don't believe that new water is getting into the header, but does anyone have any ideas of how to get the water out?
At What pressure is the boiler operating?Bob Boan
As the literature says... boiler solder makes a tough, flexible seal over leaks. Trouble is, it can't distinguish a leak from any other smallish opening, and forms a tough, flexible seal over them, too.
So...
Assume that the pigtail is clogged and the opening into the boiler. Assume that the gauge glass is clogged and its openings into the boiler. Assume that the low water cutoff is compromised. Assume that any vents which may have reached by boiler water are ruined.
And start cleaning stuff. Also check the opening into the bottom of the pressuretrol -- if the stuff reached that, it's also clogged.
Oh and drain and refill the boiler several times until you're reasonably sure the stuff is gone completely.
You've got some work to do...Br. Jamie, osb
Operating pressure set at between .5lb and 1.5 pounds0
- 109 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
