steam boiler auto fill valve
keith_27
keith_27 Member Posts: 64
If the low water cutoff probe gets dirty would this cause a problem with the water feeder when it is very cold out making the boiler run a lot ??/
    Jamie Hall Member Posts: 27,377
    It could very well.
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    Or maybe the boiler has a lot of leaks, so when it runs a lot, it uses a lot more water. “Properly” and Oversized boilers cycle off the pressure switch with long runs. Higher pressure increases leaks.
