steam boiler auto fill valve
keith_27
Member Posts: 64
If the low water cutoff probe gets dirty would this cause a problem with the water feeder when it is very cold out making the boiler run a lot ??/
It could very well.Br. Jamie, osb
Or maybe the boiler has a lot of leaks, so when it runs a lot, it uses a lot more water. “Properly” and Oversized boilers cycle off the pressure switch with long runs. Higher pressure increases leaks.0
- 120 Geothermal
- 394 Solar
