Soot on flame sensor
newhouse34
Member Posts: 9
I’ve got a lp Utica boiler and it is getting a spot buildup on the tip of the flame sensor. It is making it so the furnace won’t fire. I’ll scrape the soot off sensor and it’ll work fine for a week to two then back to same thing. Any ideas what’s causing this ? Appreciate any help !
Ok thanks. Is the air fuel ratio adjusted by a professional make adjustments to the Honeywell sv9501 or to the burner air shutters or both ?0
both. And it can't be done by eye...Br. Jamie, osb
Ok thanks a lot ! Really appreciate it0
- 50 Industry Classes
