Cold--service calls
Yep. I've been writing up a post about a system I've been working on. Was texted at 7:30Am on a weekend by the owners, their heat had gone out. Managed to get it running, but discovered a few issues while I was there. Need to answer a couple of lingering questions here before making plans.0
-29* real temp in Wisconsin, 8:30am on my 5th no heat call already. Tomorrow's low -31, ugh.
D0 -
Wow. And I thought it was cold here at +1 this morning! Stay warm everyone!0
We had record cold here in Maine in January 2009. -38F was the coldest I saw. Lots of electric stoves were left on with the oven door open! I was living in a small apartment with a propane Rinnai wall furnace. LP stopped vaporizing the tanks were too cold with the huge demand they'd had for several days.
Just the normal -15F here now.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
That's a lot better than gas stoves left on with the oven open.....Solid_Fuel_Man said:We had record cold here in Maine in January 2009. -38F was the coldest I saw. Lots of electric stoves were left on with the oven door open! I was living in a small apartment with a propane Rinnai wall furnace. LP stopped vaporizing the tanks were too cold with the huge demand they'd had for several days.
Just the normal -15F here now.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
3 -
Some family's have poor heat, or even no heat, partially because landlords ignore the issue. In the 50's and 60's It was not uncommon for folks to huddle by the open oven door when the bitter cold left them little recourse.0
-33 ambient with -56F real feel in MN this morning. For whatever reason, I got 3 no-heat calls this morning for forced air units. I only do hydronics and do not do service. Was able to talk through one over the phone and get a Dairy Queen back up and running, that guy said I was the 25-30th call he made this morning. His exhaust was iced up on the RTU.0
Only down to -5 here this morning.
One call last night from the 1933 school, 50 miles away.
The TRV sensor got broken off in a 6th grade room...."Not me" did it.
No steam leaks but valve open 100% with no steam trap.
Fortunately this was an orifice job I just did and that will only heat 60-80% of the EDR.
So I got to stay home.1 -
Man I can't imagine living on the other side of the country. Your weather is horrible!. Currently 28 degrees here and I was out working on a fuel tank line with just my t-shirt on. Of course, it is usually warmer in Homer than a lot of places in the states during the winter, so there is that.
Stay warm guys and gals.
Rick0 -
I spoke too soon. A guy I sold a pump to last winter called this afternoon saying his garage was cold and the flowmeters on 2 of his 4 loops were still. This is an atmospheric outdoor wood boiler setup with straight water in it that I tried talking him into making a pressurized system with glycol last winter but the price scared him off. I was able to get both loops thawed out and back in service luckily, doesn't appear they got cold enough to burst. One of those "I told ya so" moments that might turn into more work on the schedule soon1
Had to work on a roof in DC today. Only got down to 15 while I was up there but man the wind was blowing. It was bone chilling. I couldn’t take these double digit negative temps.Never stop learning.0
This, this, this... can always find a place to warm up or add more clothing. Can NOT always cool down. We're pretty versatile people here in MN but I, for one, would be just fine if I never saw 80 degrees again; much less 120 with 100% humidity in an attic. No thanks!sunlight33 said:This or working in an attic in Houston in July, decision, decision, decision...
4 -
There is an alternative to attic work though. Start work at midnight.
You can't get away from the cold though0 -
You can dress up for the cold, but you can't dress down for the heat past a certain point without ending up on a certain type of list.GroundUp said:
5 -
My hat's off to you in the Midwest and anywhere else where it's cold. I've never experienced the temperatures you're talking about. Hardy stock, all of you.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
We reall haven’t had a ton of calls. The cold October we had took out a lot of the low hanging fruit. Most calls have been frozen condensate lines from improper installations (attic condensing furnaces....sigh) or huge air leaks in a basement door 15’ from the furnace.
Other calls are plugged up intakes on condensing furnaces. Unless its a tight house, single pipe is the way to go. If it’s a tight house, single pipe and a passive vent, is still a better solution IMO. But... building codes.... We keep a Fernco and sawzall in the trucks.
Otherwise the usual mix of pressure switches, HSI’s and the occasional control board.
We will get a wave of calls when folks with heat pumps get their bill and realize it’s been in EM heat all month.
Weather like this is why roof vents are a terrible idea on condensing furnaces. Side wall, 1 pipe, thank you.
If the intake blocks up, you can just pop out the plastic plugs in the cabinet to get by. A flapper that made a whistling noise when it opens would be nice.0 -
-3 this morning here. Most of the people we service regularly worked fine. Had an economizer on a RTU decide to open wide and say hello to the owner. The only calls we got was from people we only seen when their lack of maintenance bites them in the rear. I had to explain to some that heating systems are designed around 7 degrees here and when its below that, all bets are off. One customer had a 10 degree night setback and could not understand how the heat did not bring the space up to the setpoint for a few hours. You techs in the mid west are heroes. I give you credit Stay safe and warmRay Wohlfarth
Boiler Lessons1 -
@RayWohlfarth
Worked for a company once (in the 90s) that only serviced commercial accounts who bought a service contract. We had 6 or 7 techs and all of them were pretty good.
Most of the stuff was maintained pretty good. It was amazing in the severe weather hot or cold we just didn't get many calls....the stuff just ran. If you had a problem it was usually a failure that couldn't have been forseen
Unfortunately, no most companies run hit and miss, No inspection, do the minimum, belts and filters and run0 -
I'm sorry, but there is absolutely no sane person who puts heating equipment on a roof!
A shovel shouldn't be part of a service call to an occupied building with no heat. I was too cold to take pictures. Nought saidServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I’ve worked passed midnight 4 days in a row now, commercial. I wish we only ran emergency calls for PM contract customers. I’m beat. 658 hours of overtime in 2018. The call I just got home from puts me at almost 100 hours of OT so far for 2019.Never stop learning.0
@EBEBRATT-Ed I stress to my people to do a good job onthe PM's so you are not on a roof in the bad weather.
@Solid_Fuel_Man i agree 100% When that wind blows on the roof, it is cold.
@Mike_Sheppard You need more techs I was alwasy afraid of wearing my techs out when working that many hours
Ray Wohlfarth
Boiler Lessons2 -
In our extreme temps, something I have never seen before. Frozen condensate inside the furnace, tubes/drains. But only found that happening with people running set backs. At 10:00 when setback occurs the furnace maybe off for a hour or so. At -30* outdoor temps follow into the furnace intake/exhaust, freezes, and never starts back up.
Of course then there all the lack of maintenance issues...…
Been a long week, so much looking forward to Saturday +35* whoohooo!
D1 -
@RayWohlfarth we have 10 burner technicians and about 90 other mechanics in the field. When the other 9 guys leave on time and refuse to answer the phone I get stuck with everything.
I get called the “yes man” ...Never stop learning.0 -
The Homer Spit! I camped there back in oh... let me think here 1980 I think it was , camped out there for a couple of weeks on The Spit till the cops chased us off! Was it Lands End Bar I frequented? Good times........🙂rick in Alaska said:Man I can't imagine living on the other side of the country. Your weather is horrible!. Currently 28 degrees here and I was out working on a fuel tank line with just my t-shirt on. Of course, it is usually warmer in Homer than a lot of places in the states during the winter, so there is that.
Rick2 -
The spit hasn't changed much since then, except the campers are much more "refined". No more blue tarp tents. And, the city is more involved in charging people to camp there. Still an impressive place to be though.
It probably was the Lands End bar, but most likely the Salty Dog!!!
Rick0 -
61 degrees right now, it was -13 just three days ago, amazing temperature swing.0
Yeah....sunlight33 said:61 degrees right now, it was -13 just three days ago, amazing temperature swing.
Concrete loves it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
> Rick
Ah yes ! the Salty Dog! those are the times I don't remember so well LOL0 -
It was 22 here this morning and you would think it’s Armageddon in Seattle.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
