Threading a damage pipe in place with the Harbor Freight Ratcheting pipe threader
branimal
Member Posts: 281
I've been relocating steam pipe valve locations as part of a remodel of my property. I cut and remove the old fittings out with a grinder followed with a hammer and chisel.
I've successfully moved 3 valves. But the last one I got a little too comfortable and nicked the threads pretty good. At least half the thickness of the pipe. I read some threads here about people coming up with temporary solutions. I'd prefer to get it done and never have to worry about this again.
The nicked riser is 1 1/4". I can create enough room in the joist bay to swing the HF ratcheting pipe threader.
My plan is cut a 1 1/4" hole in a piece of 2"x8" scrap and brace it up horizontally against the two joist bays. Then have a friend hold the pipe with a wrench below the damaged section. This is my half-**** idea of a replicating a bench vise.
Then cut the damaged threads out, level the cut portion out with a grinding disc, and then thread it.
Does this plan have a snowballs chance in hell?
Plan B - cutting my tenant's ceiling open and hoping there's a pipe coupling there. Remove the pipe and have it rethreaded on my vise or bring it to a shop to have it threaded.
The damaged pipe is on the 3rd floor. I don't see a coupling on the 2nd floor or the 1st floor (tenant's apartment). My assumption is this pipe is not greater than 10' long. So the installers hid the couplings b/w the floor and ceiling.
Problem with Plan B is my tenant is a real finicky guy. I'd rather not disturb him.
Here's the tool and a some pics of valve relocations. Successful and screw up.
https://www.harborfreight.com/38-in-2-in-ratcheting-pipe-threader-set-62353.html
https://youtu.be/pFDw4kfaPu4
https://www.coleparmer.com/i/ptfe-thread-string-plumber-s-3-32-wide-x-10-ft-length/0878245
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Thanks, for some reason I was picturing it being used to repair a burr, I misunderstood. I used almost that same procedure (saw, chisel) to separate two sections of 4" cast iron sewer and replace one with PVC. I even coupled the joint with oakum and liquid metal, instead of lamp wick and blue block. Though the leak was from rust which I chiseled loose.
So blue block is boiler-safe? For some reason I had it in my head it was no good for modern boilers.1 -
Went to HF and played around with the threader. The engagement on the ratchet mechanism is quite loose and there's no way I'd be able to swing it inside a 16" joist bay to make threads on a pipe that's not on a vise.
Great call Ironman. I'll see if my plumbing supply house has wick and some of that blue block stuff. Sounds like that'll be a rock solid seal. I should be able to keep the boiler off for 14 hours after application.Ironman said:If you didn't cut all the way through the threads, try using lamp wick followed by some good Teflon paste.
Also, make sure the horizontal pipe is pitched back towards the boiler.0 -
You can also try using a product called "X-Pando".
I spelled it wrong last time. I never have had a problem with it. Look it up. It hasn't failed me.0 -
Hate to recommend this cause it is a hack but you could turn the pipe die with a pipe wrench which would chew it up but it's been done before0
Just realize that it's forever. No sawzall/chisel will get it out the next time. One and Done.Intplm. said:You can also try using a product called "X-Pando".
New England SteamWorks
newenglandsteamworks.com1 -
Can I use thread in place of lamp wick or is the Teflon tape rolled up into a string preferable?
This will be followed up with blue block.0 -
Did that once.................EBEBRATT-Ed said:Hate to recommend this cause it is a hack but you could turn the pipe die with a pipe wrench which would chew it up but it's been done before
I think I still have the lump on my head from Dad!
Rolled up the teflon tape into a string as per the video you shared. Followed that up with some blue block and the pipe is holding. Thanks for getting me out of that jam.Ironman said:If you didn't cut all the way through the threads, try using lamp wick followed by some good Teflon paste.
