Prestige boiler w/propane fuel
nicholsnsons
Member Posts: 6
in Gas Heating
Error message 3 displayed after 5 ignition failures, reset system, no propane, system should be turned completely off until propane tank is filled & system is ready to be reset?
Water & heat are run through system not sure if power should be shut completely off or not due to water pressures?0
You will need to reset it after the propane is refilled. The tech will usually want to walk the house and check all appliances before turning the gas back on.
No harm in leaving the boiler on or off under these conditions. You may want to run the pumps if you are concerned about freezing."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
a leak test should be performed as well
After fill up & restart system working well, Thanks for the advice,0
