Prestige boiler w/propane fuel
Error message 3 displayed after 5 ignition failures, reset system, no propane, system should be turned completely off until propane tank is filled & system is ready to be reset?
  • nicholsnsons
    nicholsnsons Member Posts: 6
    Water & heat are run through system not sure if power should be shut completely off or not due to water pressures?
  • Zman
    Zman Member Posts: 7,612
    edited January 2019
    You will need to reset it after the propane is refilled. The tech will usually want to walk the house and check all appliances before turning the gas back on.
    No harm in leaving the boiler on or off under these conditions. You may want to run the pumps if you are concerned about freezing.
    Albert Einstein
  • lchmb
    lchmb Member Posts: 2,997
    a leak test should be performed as well
  • nicholsnsons
    After fill up & restart system working well, Thanks for the advice,
