Insulation double steam system post asbestos removal
melanieanderson
Member Posts: 1
Hi! I read a number of posts about why to reinsulate after removing asbestos but am confused about what materials to use. One post indicated that "anything" will work (or at least help) but another seemed to be saying that fiberglass is the only thing that will stand up to steam. (In other words, don't bother with that black foam stuff at HD.) It also appears (but I'd like to verify) that 1 inch is great, but going thicker than 1 inch has a significantly diminishing return. Also, it sounds like this something I can do myself, but if so, what protective gear should I wear?
Yes, fiberglass is the only thing which will stand up to steam these days. The black or gray stuff from the big box is worse than useless, as it won't take the temperature. And also yes, 1 inch thickess is about right. And lastly, yes this is something you can do yourself, but you should at least wear goggles and gloves and long sleeves -- fiberglass can be itchy.Br. Jamie, osb
> @EBEBRATT-Ed said:
> and a dust mask won't hurt. Long sleeves. 1" is ok. It isn't worth going thicker unless your basement is unreasonably cold
And after insulating in that case, then it will really get unreasonably colder!NJ Steam Homeowner.
Remember, when the system was designed they assumed that the mains would be insulated, and so took that into account when sizing the boiler and piping. Leaving the pipe bare makes it into another large radiating surface that was not taken into account when sizing the above was done. Consequently, the boiler could be undersized and the piping might be a bit small to handle the additional condensate generated by the pipe. Problems could result. And yes, fiberglass pipe insulation which comes in split 3' lengths with a self-adhesive strip is easiest. In a perfect world you'd insulate the mains, fittings, and branches to the radiators, but at least the mains is a good start.1
@FriendlyFred helped me understand the cost/benefit of thicker insulation when I asked a similar question here:
https://forum.heatinghelp.com/discussion/167865/steam-pipe-insulation-diy#latest
The take away was 1" thick was best for me.
If you use your basement for laundry/storage etc, and you plan to cut the pieces down there, I recommend vacuuming up thoroughly after the job or else the particles will be tracked upstairs after.New owner of a 1920s home with steam heat north of Boston.
Just trying to learn what I can do myself and what I just shouldn't touch1
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
