Cbn 075 submerged ground faults on high fire
balwit
balwit Member Posts: 1
I recently had a pipe break that submerged my boiler under 3ft water. I was able to quickly remove water and dry most components. I replaced the two stage gas valve with a new one. Boiler fires up , runs for a minute or two then (I think when attempting to high fire ?) Trips the new GFCI..
  • kcopp
    kcopp Member Posts: 4,688
    If the boiler was submerged by all rights you need to replace the whole thing.
    DZoro
    Jamie Hall Member Posts: 27,396
    edited January 2019
    Not quite strong enough, there, @kcopp - at least in these parts if a fuel burning appliance has gone under water, it must be replaced. No ifs, ands, or buts.
    DZoroIronman
  • Ironman
    Ironman Member Posts: 7,904
    Big brother mandates replacement of that boiler.
    DONT ATTEMPT TO USE OR REPAIR IT!
    Your insurance should cover it.
    Bob Boan
    Steamhead Member Posts: 18,528
    This.
    Consulting
    EBEBRATT-Ed Member Posts: 20,236
    Sorry to say but it has to go.
    No safety control can be trusted once water hits it
