Cbn 075 submerged ground faults on high fire
balwit
Member Posts: 1
I recently had a pipe break that submerged my boiler under 3ft water. I was able to quickly remove water and dry most components. I replaced the two stage gas valve with a new one. Boiler fires up , runs for a minute or two then (I think when attempting to high fire ?) Trips the new GFCI..
Not quite strong enough, there, @kcopp - at least in these parts if a fuel burning appliance has gone under water, it must be replaced. No ifs, ands, or buts.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England2 -
Big brother mandates replacement of that boiler.
DONT ATTEMPT TO USE OR REPAIR IT!
Your insurance should cover it.Bob Boan
kcopp said:
If the boiler was submerged by all rights you need to replace the whole thing.
Jamie Hall said:Not quite strong enough, there, @kcopp - at least in these parts if a fuel burning appliance has gone under water, it must be replaced. No ifs, ands, or buts.
This.Ironman said:Big brother mandates replacement of that boiler.
Your insurance should cover it.All Steamed Up, Inc.
Consulting0 -
Sorry to say but it has to go.
No safety control can be trusted once water hits it0
- 120 Geothermal
