Need some help please
Alf1962
Member Posts: 2
I have a boiler for heat and hot water . after we changed propane companies i noticed my heat is not as hot as it was previously.. My oven is also not as hot
My toekick heaters are not blowing that hard as it used to, and they are also not as hot.. What could be the problem. My water for bathing is hot enough.. I hope some one can help
Did someone change the operating temp?
There are hundreds of boilers out there and thousands of ways to pipe them. A description or pictures of yours would help."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Or, the gas pressure could be set lower if they changed the regulators.
If the new company set them correctly, which they probably did, they won't set them any higher. But it's worth a call to ask them to check them.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.2 -
They are coming out on thursday.. My wife asked a maintnance person were she works and he thought the same thing0
