Need some help please
I have a boiler for heat and hot water . after we changed propane companies i noticed my heat is not as hot as it was previously.. My oven is also not as hot
My toekick heaters are not blowing that hard as it used to, and they are also not as hot.. What could be the problem. My water for bathing is hot enough.. I hope some one can help
  • Zman
    Zman Member Posts: 7,614
    Did someone change the operating temp?
    There are hundreds of boilers out there and thousands of ways to pipe them. A description or pictures of yours would help.
    Albert Einstein
  • Ironman
    Ironman Member Posts: 7,927
    Or, the gas pressure could be set lower if they changed the regulators.
    If the new company set them correctly, which they probably did, they won't set them any higher. But it's worth a call to ask them to check them.
    Bob Boan
    STEVEusaPADZoro
  • Alf1962
    Alf1962 Member Posts: 2
    They are coming out on thursday.. My wife asked a maintnance person were she works and he thought the same thing
