Bell and Gossett series 100 noise
sheets105
Member Posts: 2
Just replaced B&G series 100 motor and coupling. On start up, runs quiet and boiler activates. Within a few seconds, get a noise in the area of the bearing assembly. I've ordered a new assembly and will be installing it. Any other possible causes for the noise?
Sounds like pebbles?0
Coupler?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Did the new motor come with new rubber mounts. If it did then yes it's the bearing assembly.0
Thank you everyone. The motor assembly is brand new as is the coupler. I've just noticed there are metal shavings all over the bearing assembly, so guessing there is a problem in there. Should have the new bearing assembly today, so we will see....0
Those were and hopefully still are a great workhorse.
I have repaired a few and learned that, (working for homeowners) when the bearing seal goes out it is time for an upgrade.
Hopefully you get good years out of it.
Just observe the oiling instructions, originally there were 3 points.
Do not over oil the motor, if there are ports.0 -
Wonderful circulator. There are many installed on my route and I have great respect for them.
Youtube video helps, especially minute 5:00 when they show you how much oil to use.https://www.youtube.com/watch?v=Pk8rtXS1S-k
Gretzky is "The Geat One" but eventually he did have to hang up his skates.
Nobody will ever top him even though the kids today are stronger, faster, more conditioned players. But Gretzky cant compete anymore.0 -
Lol I remember when the coupler broke at 3:00am on my series 100 HV, and ceiling radiant. I thought the house was coming apart.........0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
