Mystery outdoor steam pipe
SeanBeans
Member Posts: 525
I walk by this pipe coming out of an older building everyday when I’m going to my van. Sometimes it’s blowing out steam like this and sometimes it’s not..
I walked out front and saw that most people have their windows 1/2 open some fully.. what’s going on?
https://youtu.be/cPqSYch7DKg
What else could there be in an older buildings basement that would need/do this?
https://youtu.be/cPqSYch7DKgWhat else could there be in an older buildings basement that would need/do this?
What @JUGHNE said.
Many commercial buildings don't feel the need to maintain there steam traps. So the steam gets dumped. Big waste they dump more steam than needed to heat the building.
Just like dumping gas from a gas leak or pouring oil down the drain. Big waste of money. Fixing the traps would save them a bunch of money.
But the worst part is they are absolutely killing their boiler with all the fresh make up water1 -
My company does work for the property management company. They have ALOT of properties.
I talked to one of the managers and told him about it but haven’t heard back.
Maybe I’ll do a follow-up.
The first thought in my mind was the relief valve was going... which is scary.
I’ll do a follow up.. my apartment is directly across the alleyway0 -
Well, you're screwed then. Either you'll tell them what to do to fix it right & you'll be 'that guy who wants too much money'; or you'll bandaid it & you'll be 'that guy who doesn't charge too much for steam stuff' & get all the crap work.SeanBeans said:My company does work for the property management company. They have ALOT of properties.
