Can I Leave Boiler Empty for A While
Steinway
Member Posts: 9
I thought I had posted this but it’s not in my threads. Sorry if this is posted twice.
Burnham Gas Steam 20yrs old?
My drain valve is dripping and I’m going away. Can I drain my boiler to below the valve and leave it like that for two weeks or is that bad?
I don’t think I’ll have time to replace it before I leave.
On replacing it. The valve is attached to a 4 inch nipple and screwed in to the boiler. A plumber said I can just unscrew the whole assembly and replace it. Seems simple enough. Where it screws in to the boiler there is a giant nut. Do I need to secure or loosen this nut? I can’t really reach it to get a wrench around it.
Sorry there are no pics. I’m sure that would be helpful. I’m at work but I’m hopeful someone knows what I’m talking about - but wise. I’ll add pics when I can.
Single pipe steam radiators, if that matters.
Everything seems simple until you put the wrench on the valve and the valve or nipple breaks off in your hand, then things might get complicated!
Pictures will be required for anyone to be able to help with opinions.
When you go away, are you powering down the boiler? If so, I'd just put a bucket under it (or I assume there's already a bucket under it LOL) and let it drip.NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0 -
I should mention - a cap won’t work because it appears to be leaking out of the stem to the handle, not dripping from the opening. I did put a cap on it and then noticed the stem leak.
Yes, I will shut down the boiler when I go away if I drain it. I can’t just leave a bucket there because with the amount it is dripping it will fill and over flow while I’m away.0 -
Ahh, well that’s quite a drip! My opinion is that yes, you can lower the water level and shut it down, but I’m just a homeowner, so my opinion is always open to adjustment!NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
If it's leaking out of the stem to the handle, have you tried tightening the packing nut? Or even taking the packing nut off and repacking it?
I agree, sounds simple and can be a bear, but... worth a try.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
It's a simple fix to replace the packing or replace the valve. Any plumber or even a handyman can do it.
You did mention steam and 4", so I'd like to see a picture of it up close, and a picture of the boiler and the piping.
When you were talking to the plumber, why didn't you just have him do it for you?There was an error rendering this rich post.
Here are pics of that valve connecting to the unit. Does it look like I can just unscrew the valve? I’m not sure about that nut.0
That "nut" is a hex reducing bushing. It will probably not move, it is iron screwed into an iron boiler.
Your drain is a brass fitting screwed into the iron bushing.
The brass usually unscrews easier than any iron fitting.
Personally I would replace that leaker with a ball valve that has a hose adaptor screwed into the end, add a cap so if the valve handle gets kicked open the boiler will not drain.
The full port ball valve lets you drain any sludge out of the boiler rather than plug-up like the present (poor excuse of) boiler drain might.
It would take a 4" nipple, ball valve, hose adaptor and brass cap.
I would use a brass or stainless steel nipple going into the boiler.2 -
I’d drain, repack.
Let ‘er drip until after your trip 😅NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
Why not shut off the boiler feed (no draining) and just let it drip until it finds it's own level?0
It looks like the packing nut is threaded on crookedly, so I would try to repack the valve first, and properly reinstall the nut.—NBC0
try turning the valve open a bit, then first loosen the packing nut a bit, then tighten the packing nut down and then turn the valve handle back off off. this often works for me.0
If nut won't unscrew I'ld remove the plastic knob and if shaft isn't plastic I'ld heat the nut with a propane torch to expand it. Then it might come off easily. Then can replace packing.
I've worked on lot of rust nuts and bolts on cars amazing how much a little heat can help.0 -
Thanks everyone for the great advice. People helping people is what this time of year is all about. Your concern for a total stranger has put me in the holiday spirit.
I've been solo parenting and super busy with work so I wasn't able to address this until 11pm last night after my son was asleep; after a trip to HD in his pajamas, that is.
I drained the boiler and repacked the stem (@STEVEusaPA @Jamie Hall). Then I refilled the boiler and cranked up the heat because from what I've gathered from other posts, you always want to run the boiler after you fill it.
I checked it first thing this morning and again just now and I appear to be leak free.
I do really want to change out that valve but I'll wait until it's shorts season. I'm pretty handy, I'm just more wood and saws than water and wrenches. I'm sure I can tackle that though.
Huge thank you @JUGHNE for that very detailed post on replacing the valve including listing the parts I will need. That was extremely cool and kind of you! I will definitely use a full port valve, per your suggestion.
Merry Christmas to all who celebrate it, Happy Holidays to those who don't and Happy New Year to everyone!1 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
