Btu question
keith_27
keith_27 Member Posts: 64
edited November 2018 in Domestic Hot Water
what is the btu for bare 3/4 copper in the basement
  • Ironman
    Ironman Member Posts: 7,902
    That depends upon the temp differential between the pipe and the ambient air. At 70* ambient air and 180* in the pipe, it's 45 btus per lineal foot.
    Bob Boan
    Gordy
    hot_rod Member Posts: 27,344
    flow rate inside the pipe as well as any air movement around it will have some effect. Keep in mind the temperature drop, measure SWT and RWT, add those two then ÷ by 2 to get average temperature across the run. Use that average for your estimates.
