Corroded drain spigot on back of Dunkirk
Member Posts: 8,043
Anyone tried/succeeded/failed to do something about this situation on a rear drain port of a Utica/Dunkirk boiler?
What is the port going into? Cast iron? A nipple?
Thanks, I’m scared to even take a picture of it 😬
Free NJ and remote steam advice:
https://heatinghelp.com/find-a-contractor/detail/new-jersey-steam-help/
See my sight glass boiler videos:
https://bit.ly/3sZW1el
It goes right into the cast-iron boiler section. The ideal replacement is a ball-valve type boiler drain, which makes the boiler much easier to flush out.All Steamed Up, Inc.
Consulting-1 -
Thank you @Steamhead. Someone from the past put a gate valve on the return next to the hartford loop at the same height so maybe that’s OK (I’ll change it to a ball valve next spring), but I’m scared this one is gonna give out. It’s got a drip currently 😓
But maybe there’s not a direct path between sections so that valve that works maybe isn’t good enough—I’m ignorant of the internals/sections.NJ Steam Homeowner.
Try pulling it if it breaks though your going to have to cape it out. It’s doable either way. Put a nice 3/4 full port ball valve.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......-1 -
Thanks Dave, I might wait until spring for that one too, unless it forces me otherwise
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
