Gas meters for LP
Solid_Fuel_Man
Member Posts: 2,644
in Gas Heating
I'm looking to monitor usage on LP with a gas meter. Looking at the AM-250 as they are cheap and plentiful. Total connected load is 150,000 btu/hr.
With this type of meter related at 5 psi still work on the 11"WC side of a propane distribution system? What I'm reading seems to indicate it would, didn't know what kind of pressure drop I can expect, or if a different meter would be recommended.
Happy Thanksgiving All!
Ok, this is exactly what I wanted to know!
Thank you so much.
I'm now digesting Turkey & trimmings, making room for pie(s)!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I primarily heat with an OWB but was wanting to see what my LP water heater was using (if any) during the winter while on wood so I put this in. I've had a used Lochinvar KBN105 sitting in the basement waiting for install when I switch to radiant in the house and was hoping to monitor what it costs to heat the place with LP versus wood on a day to day basis but haven't made it that far yet. Haha0
I have a 115 gallon indirect, which I heat once a day with wood. Burn one fire a day all winter. The large storage of DHW allows me (most days) to ride out the 20 hour period between fires.
Now when we have both sides of the family over and all the women are cooking and then washing copious amounts of dishes I had to build a fire earlier of which about 1/3 went directly toward DHW.
Have been very happy with the solar indirect purchase 8 years ago.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
