Nashville Hotel
SlamDunk
Sounds like the pool boiler, again....
Low return water temps and poor maintenance no doubt."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
This is the 3rd hotel in a week. Motel 8 in Colorado and a Holiday inn Express in North Carolina.0
A CO detector from Lowes may keep you from dying but not from getting poisoned and taken to a hospital.0
Yes it is sad.
In this hotel, the service suffered a long time ago. Now there are have problems with the boiler.A series of failures
Dangerously.
http://www.defenderdetectors.com/
A few years ago, friends of mine were in a motel lobby waiting to be picked up for a class. Some wore low level detectors on their belts. Started going off. Told the desk agent to call the fire department. No. OK, we'll do it. I think he finally called. Pool heater, no combustion air.0 -
I have a big-box CO detector on each floor of my house (required by local code). But in my bedroom, I also have an earlier model of one of these:
http://www.aeromedix.com/co-experts-2017-ultra-low-level-carbon-monoxide-detector
2 -
Ditto, except my older CO Experts detector reached its end of life and was replaced with that current version.Jean-David Beyer said:I have a big-box CO detector on each floor of my house (required by local code). But in my bedroom, I also have an earlier model of one of these:
1
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
