LOL had to steal and paste
GW
Member Posts: 5,133
"I don't care how you do it, just strap everything down!!"
*facepalm*Terry T
The person could have at least just screwed through the bed rail, and liner like the forward ones.
Nothing beats self tapers with an impact driver to put them in, and take them out. Those ratchet straps can be a pain to get loosened sometimes
In reality where would you hook them, to the fender.........0 -
You can get tie down hooks that drop into those bed sockets also.Bob "hot rod" Rohr
My bed liner has T shaped tie down anchors built into the liner.
Kind of a PIA as they are down near the floor.0 -
I would bet that there is a history between the driver and the owner of the truck.0
Probably "lost his load" once before and wanted to make sure he didn't loose this one.
His boss probably was too cheap to buy him ratchet straps0 -
There's a hole or two at the bottom of the fender and yes it's an older truck but c'mon! LOL!0
He is the boss and he's on his way to do one of those "special" steam installations!EBEBRATT-Ed_9 said:Probably "lost his load" once before and wanted to make sure he didn't loose this one.
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
