Decora style line voltage heating stat?
ratio
Member Posts: 4,229
You want like a 4 gang box and plate with 3 switches and 1 thermostat?
Nope.
What type of heat/cool equipment do you have.
Its possible controls can be converted to low voltage and interface a wireless thermostat that doesnt NEED to be mounted anywhere.0 -
3 gang, but that's the idea. It's just a fart fan with a 1200 watt heater in it. I'd like the controls all beside the door, but the stack runs up through that wall about a foot from the opening, so not much room to work with. I could convert it to low voltage, but that seems like a lot of work to get a wire to heat up. If I do that, I'll probably stick an SCR in there & control it with an analog signal.
Not having much luck so far, might have to convert to LV control any way.
Just use a low voltage stat and a relay for a 1200 watt load. Not sure if there is anything available to go into a switch box though.
You could just use another decora switch to power up said line voltage thermostat mounted in another locating in the bathroom where you dont need to get at it. Then it's just essentially a high limit.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I forgot about these , the MED relay .They were used on line voltage systems and gave you a option to install a 24V thermostat . They were designed to fit in a wall box ...Not sure if they still make them .
I don't know of one.
It is a good idea to keep them separate. Dimmers and GFI's will give you inaccurate readings
Albert Einstein0 -
After minutes and minutes of Googling, I've given up; I set another box an inch away from the 3 gang for the thermostat. It's just too durned easy compared to the amount of work necessary to make anything else work.
But thanks for the input!0 -
@ratio,
I would take a look at the instructions. Most of the bath fan, light and heater combos I have seen usually requires a dedicated 20amp circuit.0 -
Got a 20A circuit for the heater, separate circuit & switch legs for the fan & light. I thought about putting the heater on a timer, but I just can't bring myself to run a heater without any kind of feedback control. It'll be ok, I just think it'll look a little silly with ganged switches & a stat crammed into a separate box an inch away, but there really isn't any room.0
Put it on a clock-spring timer, you know the mechanical ones....I use them exclusively for fart fans! Now there is never a fan left on for 8 hours because someone stunk it up and forgot to turn off the fan.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
I'm a little leery of putting it on a timer. IDK how the space will react to 1k2 watts of power. It's only about 50 sq ft. The last thing I want to do is make it uncomfortable in there, even for a little while.0
Something to think about, thanks.0
Lutron has a Decora style “Stat” but it requires a remote sensor and wireless receiver $$$0
@ratio
Most bath fans with electric heat you just turn them on and let them rip. When it get hot they will shut it down. If you put a stat on it they will leave it on and forget to shut it down. Do you want this thing to be able to be on all the time?
Also not sure about (2) 120volt circuits in the same fan, don't think that will fly. Multiple disconnects etc
Basically the fan is a listed UL appliance along with the switches that come with it. To be legal it must be wired in accordance with the instructions0 -
- 50 Industry Classes
