Emergency 3-boiler replacement in NYC
JohnNY
JohnNY Member Posts: 3,324
Busy days here. Shuffled our schedule to fit in this multiple boiler replacement in a shelter in Manhattan. Such gratitude from the residents. Offers to help. Making us coffee. Smiles and handshakes all day long. This is the good part of being a skilled tradesperson.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
HenryIronmanSailahkcoppSolid_Fuel_ManErin Holohan HaskellDocfletcherGBartethicalpaul
  • Le John
    Le John Member Posts: 247
    @JohnNY - It's amazing the box that sits over the burners is able to support the load of cast iron that sits on top of it. What is the weight of that cast iron after its fully assembled?
  • Nice to see your tech actually reading the installation instructions!—NBC
    HenryJohnNYkcoppGBart
    hot_rod Member Posts: 25,193
    I'll assume you stepped back just to take the pic :)
    Big of you to step up for folks and jobs like this. Also the Society work you do.
  • Henry
    Henry Member Posts: 998
    As a code guy, do you have any combustion air and are you required to put a liner on this install?
  • JohnNY
    I was told each section is just shy of 250 lbs. These are 4-section boilers. Yeah, you're right. Strong boxes right there!
    Classes
  • JohnNY
    Nice of you to say so, Bob. Thank you.
    Classes
  • JohnNY
    There are two combustion air intakes, big ones, one high and one low. The chimney is B-vent. This was a FEMA rebuild after Sandy so it was inspected to the hilt. I don't know the full story but I'm told they were allowed to rebuild the flooded boilers back then. Now they're in the garbage. They didn't last. Shocker.
    Classes
  • ScottSecor
    ScottSecor Member Posts: 987
    Looks like your men are doing a nice job, keep the photos coming. Is it a steam or hot water job?
    Remember, those same style boiler bases (just larger) are used for the entire line of W/M LGB boilers, all the way up to 12 sections. On boilers over 12 sections they basically use to bases.
    EBEBRATT-Ed Member Posts: 18,011
    @JohnNY, glad you could step in and help them. It's nice that there are still SOME customers that appreciate all the hard work.
    Good job!!
    JohnNY
  • Is this trio for steam, or hot water, and what is the control strategy?—NBC
  • JohnNY
    This is a hot water job and the boilers are staged via an existing Heat-Timer HWRQ. I'm going to try to get them to agree to utilizing the optional BACnet communication module and get going with some indoor/system feedback and remote monitoring.
    Classes
    kcopp
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Great work, it's good to do it right and be appreciated!
    The lighting and background are also near perfect, magazine quality.
    JohnNY
  • Good lighting is required for reading the manual!—NBC
    JohnNY
