Type of water to use
RWALD
RWALD Member Posts: 23
I run triangle tube boilers is it ok to use RO water in the system? I have floor heat and fin pipe.
    Jamie Hall Member Posts: 27,377
    Yes -- but you will want some sort of corrosion inhibitor and pH buffer in the system. RO is pretty "hungry" (but not as aggressive as DI)
  • RWALD
    Ive had multiple heat exchangers start leaking in the units. They are 399 btu Natural gas units. I run fernox in the system. System's been goin on 3 years now
  • Does the floor tubing have an Oxygen barrier?—NBC
  • RWALD
    Yes it is Oxygen Barrier pex a
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    May be time to send a water sample to a lab and see what is the best direction to go as far as treatment/adding chemicals.
    hot_rod Member Posts: 27,473
    There was a batch of short life heat exchangers on the market a few years back, weld issues. Contact the rep to see if yours are in the date code range.
    kcopp
