Type of water to use
RWALD
Member Posts: 21
I run triangle tube boilers is it ok to use RO water in the system? I have floor heat and fin pipe.
Yes -- but you will want some sort of corrosion inhibitor and pH buffer in the system. RO is pretty "hungry" (but not as aggressive as DI)Br. Jamie, osb
Ive had multiple heat exchangers start leaking in the units. They are 399 btu Natural gas units. I run fernox in the system. System's been goin on 3 years now0
Does the floor tubing have an Oxygen barrier?—NBC0
Yes it is Oxygen Barrier pex a0
May be time to send a water sample to a lab and see what is the best direction to go as far as treatment/adding chemicals.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
There was a batch of short life heat exchangers on the market a few years back, weld issues. Contact the rep to see if yours are in the date code range.RWALD said:Ive had multiple heat exchangers start leaking in the units. They are 399 btu Natural gas units. I run fernox in the system. System's been goin on 3 years now
Living the hydronic dream1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
