Legitimate Reasons to Raise Steam Pressure
RedMechHVAC
Member Posts: 6
I know that oftentimes on steam boilers, people will unnecessarily raise steam pressure to compensate for system deficiencies when there is really another issue that needs to be addressed.
What I'm wondering is, what are some actual, legitimate reasons that one would need to raise boiler pressure?
Thanks in advance, sorry for a novice question.
Assuming that we are talking heating systems here, and not process steam or power -- the first one that comes to my mind is that certain types of heating coils or reheat coils in air handlers do require a higher pressure sometimes.
I'm sure @Steamhead can come up with some more.Br. Jamie, osb
I have seeen higher steam pressures on steam to water heat exchangers, typ 5-7 PsigRay Wohlfarth
Boiler Lessons0 -
Legitimate reasons to raise steam pressure?
I suppose if you want to get into New York early Tuesday night and make headlines......Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Smaller distribution piping - like Gerry's mini tube?0
To raise condensate to a higher level than the trap discharge level.gwgillplumbingandheating.com
Dry cleaners use high pressure.
Fulton downfire 90 psi0 -
As already mentioned, air handler coils, heat exchangers, high temperature requirements, lifting condensate, steam humidification
I0
- 167 Indoor-Air Quality
