Legitimate Reasons to Raise Steam Pressure
I know that oftentimes on steam boilers, people will unnecessarily raise steam pressure to compensate for system deficiencies when there is really another issue that needs to be addressed.
What I'm wondering is, what are some actual, legitimate reasons that one would need to raise boiler pressure?
Thanks in advance, sorry for a novice question.
    Jamie Hall Member Posts: 26,839
    Assuming that we are talking heating systems here, and not process steam or power -- the first one that comes to my mind is that certain types of heating coils or reheat coils in air handlers do require a higher pressure sometimes.
    I'm sure @Steamhead can come up with some more.
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,897
    I have seeen higher steam pressures on steam to water heat exchangers, typ 5-7 Psig
    Ray Wohlfarth
    Boiler Lessons
  • ChrisJ
    ChrisJ Member Posts: 17,070
    Legitimate reasons to raise steam pressure?
    I suppose if you want to get into New York early Tuesday night and make headlines......
  • Phil53
    Phil53 Member Posts: 73
    Smaller distribution piping - like Gerry's mini tube?
  • gerry gill
    gerry gill Member Posts: 3,083
    To raise condensate to a higher level than the trap discharge level.
    gwgillplumbingandheating.com
    HVACNUT Member Posts: 7,233
    Dry cleaners use high pressure.
    Fulton downfire 90 psi
    EBEBRATT-Ed Member Posts: 19,591
    As already mentioned, air handler coils, heat exchangers, high temperature requirements, lifting condensate, steam humidification
    I
