large residential oil furnace needed
zepfan
Member Posts: 441
in Oil Heating
We are looking at a job which is a complete system replacement, the house has a 200 mbh 1972 oil furnace, and five tons of ac. The house is about 5,000 ft. 2 and I am sure if it was built today they would have had two systems. While the furnace may have been too large from day one, the issue is I can't seem to find anything close to the size of this made now. I am seeing most furnaces topping out at around 132 mbh. Any assistance would be much appreciated. Thanks to all.
The Weil-McClain 380 comes in at 209 net MBtuH for steam. The n80 series goes up from there. Cedric is a 580 firing at 2.75 gallons per hour, for instance. Check your EDR, though!Br. Jamie, osb
Heat loss calculation is needed.To learn more about this professional, click here to visit their ad in Find A Contractor.1
Isn't the poster asking about forced air?Jamie Hall said:The Weil-McClain 380 comes in at 209 net MBtuH for steam. The n80 series goes up from there. Cedric is a 580 firing at 2.75 gallons per hour, for instance. Check your EDR, though!
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
Stupid assumption on my part. Maybe he is; not clear. Where's my coffee?JohnNY said:
Thanks to all for responding. Yes this is a forced air furnace with five tons of central ac0
Adams manufacturing in Cleveland makes them up to 1,000,000 btu.0
As stated above it is 2018, you have to do a heat load calc, you can't pull a permit without, THEN you pick the equipment, I wouldn't be surprised if your actual load was @ 125,000btu/hr.0
I echo the above. Please do a heat load calculation for your own education.
Slantfin has an app. It is tedious but worthwhile.
I had an oil company contractor walk in and quote a 225,000 BTUH, input, oil furnace when a 112,000 BTUH, input, would do. Think of all the oil we would have had to buy for that beast for years and years!1 -
What is sad is that today many times contractors do have a load calc to give the inspector and they do miraculously match the output of the unit but they are a complete FRAUD.
Or the contractor tells the supply house "yeah its like a 30 x 45 house with a um 8ft ceiling and 2 bedrooms, I think the side walls are 20, yeah" and they design build off that0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
