Laars Mascot, not proud
hot_rod
hot_rod Member Posts: 25,381
of the fact that I haven't serviced in since 2007! Even though it is next door at my mother in laws :(
Opened it today and I am amazed at how well it has aged. LP from multiple sources over the years, concentric vent kit. Piped to a HydroLink hydraulic separator, onboard 15-62 Grundfos.
It is a combi and it cycles a lot with constant and intermittent DHW draws every day.
Many folks have slammed this Giannoni/ Sermeta heat exchanger design over the years. I predict the boilers that were built properly with good drainage and top brand electronics and inducers will last a long time, 20 years plus.
Wondering if the fire tube design will prove to be this robust?
GroundUpSolid_Fuel_Mankcopp
