Smart vents?
Erin Holohan Haskell
Member, Moderator, Administrator Posts: 2,360
I came across this article about a new smart ventilation system. What do you think?
President
HeatingHelp.com
Not going to work well with a fixed speed blower.To learn more about this professional, click here to visit their ad in Find A Contractor.0
Looks like a rich man's zoning system, possibly with the added benefit of batteries to replace in every room?
Let's see how it works out for the early adopters. Without concomitant changes to the designs of the central equipment, something like this could easily cause more problems than it fixes.
@ratio, I know what you mean about the batteries. The specs say "Extended battery-life with Energy Harvesting" but they don't elaborate on that. I agree that it'll be interesting to see where this goes.
President
HeatingHelp.com0 -
Another band-aid for scorched-air. Tear it out and go hydronic!All Steamed Up, Inc.
Consulting1 -
If you think about the high end home that needs AC and a new furnace but has no zones, this is kind of a slick solution. You install a new furnace with an ECM motor and one of these in each room and you have a pretty good band aid.
The battery's are an issue. Not sure why they don't hide a little anemometer to charge them."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
As has been pointed out, a fixed speed blower would be a problem. Probably need variable speed or a bypass with an adjustable damper. The batteries are problematic: changing batteries in multiple rooms would be a pain. And then, of course, the question arises of cost effectiveness, although it seems designed primarily for comfort. What will it save, and what is the payback period?0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
