Smart vents?
Erin Holohan Haskell
Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
I came across this article about a new smart ventilation system. What do you think?
President
HeatingHelp.com
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Not going to work well with a fixed speed blower.
  • Erin Holohan Haskell
    Good point. Thanks, @Robert O'Brien.
    President
    HeatingHelp.com
  • ratio
    ratio Member Posts: 4,176
    Looks like a rich man's zoning system, possibly with the added benefit of batteries to replace in every room?
    Let's see how it works out for the early adopters. Without concomitant changes to the designs of the central equipment, something like this could easily cause more problems than it fixes.
    @ratio, I know what you mean about the batteries. The specs say "Extended battery-life with Energy Harvesting" but they don't elaborate on that. I agree that it'll be interesting to see where this goes.
    President
    HeatingHelp.com
    Steamhead Member Posts: 18,210
    Another band-aid for scorched-air. Tear it out and go hydronic!
    Consulting
    ratio
  • Zman
    Zman Member Posts: 7,611
    If you think about the high end home that needs AC and a new furnace but has no zones, this is kind of a slick solution. You install a new furnace with an ECM motor and one of these in each room and you have a pretty good band aid.
    The battery's are an issue. Not sure why they don't hide a little anemometer to charge them.
    Albert Einstein
  • fastd
    fastd Member Posts: 16
    As has been pointed out, a fixed speed blower would be a problem. Probably need variable speed or a bypass with an adjustable damper. The batteries are problematic: changing batteries in multiple rooms would be a pain. And then, of course, the question arises of cost effectiveness, although it seems designed primarily for comfort. What will it save, and what is the payback period?
