Industrial Burner Install
Mike_Sheppard
Mike_Sheppard Member Posts: 698
This is a job a couple co-workers of mine are starting. Hopefully I will be able to participate in the commissioning once it is ready. I haven't seen many industrial boiler posts so I figured I would share. This is an IC brand mesh burner that is going on a 1,500hp Cleaver Brooks high pressure steam boiler. The mesh burner is 10 feet in length and 2.5 feet in diameter. The other picture is the blast tube that the mesh burner will slide into which will be mounted on the front of the boiler.
As the job progresses I will try to update with more pictures.
Never stop learning.
ratioSolid_Fuel_Man
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    What kind of process and pressure will the CB be running? 4 pass scotch marine type?
  • Mike_Sheppard
    @Solid_Fuel_Man I’m not 100% sure what all of their processes are, but it’s a research facility so I’m sure they have autoclaves and the such. They heat the building with steam during the winter as well. I believe they’re running around 150psi.
    Yep, 4 pass scotch marine. Old burner was a Natcom.
    Solid_Fuel_Man
    Steamhead Member Posts: 18,187
    You could cremate someone in there and the neighbors would never know....... >:)
    Consulting
    Solid_Fuel_Man
  • Solid_Fuel_Man
    I like the CB scotch marine 4 pass, on water or steam. I've only worked on the dryback version though, with CB modulating oil burner.
  • Mike_Sheppard
    The one the burner is going in is a wetback I believe. The only wetback CB I’ve seen. The dryback is much more common.
    CB is one of my favorite boilers.
    EBEBRATT-Ed Member Posts: 19,502
    CB sells a lot of boilers. Not a fan of 4 pass boilers though. The tube sheets are subjected to wide ranging temperature differences. 4 pass also has a high pressure drop on the combustion side. Wetback is a lot better boiler also more expensive.
    JMHO
    Very interesting project though
  • Mike_Sheppard
    The British Embassy has (or had) wetback firetube boilers. I haven’t been there in years but I used to service and even replace tubes in their boilers.
    The British Embassy was the first building in the US to have radiant heating.
  • Mike_Sheppard
    Another picture from my co-worker. Blast tube and burner mounted. Blower motor/intake mounted on top.
