Industrial Burner Install
Mike_Sheppard
Member Posts: 698
This is a job a couple co-workers of mine are starting. Hopefully I will be able to participate in the commissioning once it is ready. I haven't seen many industrial boiler posts so I figured I would share. This is an IC brand mesh burner that is going on a 1,500hp Cleaver Brooks high pressure steam boiler. The mesh burner is 10 feet in length and 2.5 feet in diameter. The other picture is the blast tube that the mesh burner will slide into which will be mounted on the front of the boiler.
As the job progresses I will try to update with more pictures.
Never stop learning.
2
What kind of process and pressure will the CB be running? 4 pass scotch marine type?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
@Solid_Fuel_Man I’m not 100% sure what all of their processes are, but it’s a research facility so I’m sure they have autoclaves and the such. They heat the building with steam during the winter as well. I believe they’re running around 150psi.
Yep, 4 pass scotch marine. Old burner was a Natcom.Never stop learning.1 -
You could cremate someone in there and the neighbors would never know.......
Consulting1 -
I like the CB scotch marine 4 pass, on water or steam. I've only worked on the dryback version though, with CB modulating oil burner.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
The one the burner is going in is a wetback I believe. The only wetback CB I’ve seen. The dryback is much more common.
CB is one of my favorite boilers.Never stop learning.0 -
CB sells a lot of boilers. Not a fan of 4 pass boilers though. The tube sheets are subjected to wide ranging temperature differences. 4 pass also has a high pressure drop on the combustion side. Wetback is a lot better boiler also more expensive.
JMHO
Very interesting project though0 -
The British Embassy has (or had) wetback firetube boilers. I haven’t been there in years but I used to service and even replace tubes in their boilers.
The British Embassy was the first building in the US to have radiant heating.Never stop learning.0 -
Another picture from my co-worker. Blast tube and burner mounted. Blower motor/intake mounted on top.Never stop learning.0
- 120 Geothermal
- 394 Solar
