Steam replacement getting started
Dave0176
Member Posts: 1,178
Got a call from a HeatingHelp Wally in Sunset Park Brooklyn NY. Four family apartment tenement with two 2-1/2” mains. We’re going in with a Weil-McLain EG-75 and 4” header.
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
smart choice on the header, post some completed pics"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
How correctly was the old one sized?—NBC0
Header under construction. Doing some homework.
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Here is what the old one looked like
The EDR came in at 698
Great work, as always, but you should probably take the address off this post. NYC inspectors are no longer playing around with gas installations.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes-1 -
Dave, I have a question on the equalizer after the drop and before the two take off, what is the length pipe you used and is there always a minimum length?0
Piped in...........
I cannot force people to spend money, I can only suggest how to spend it wisely.......5 -
I’ve worked in DC on steam boilers for almost 12 years now and I’ve never seen a single install that pretty.
In this area it’d probably have on riser, no header or an incorrectly piped header, and pressure set to 10psi. Inevitably I deal with this every winter here...
Great lookikg work! Love it
@AMservices I can sympathize. I’m not in charge of quoting jobs but I get to deal with hack installs all winter every year.Never stop learning.0 -
Beautiful as always @Dave0176. And good for you to rip that entire old header out and start new.
The results speak for themselves.New England SteamWorks
newenglandsteamworks.com0 -
Not really, unless it’s in great shape and a rare fitting, for instance one job last year I saved a 2X2X3” cast iron bullhead tee. Took it home bead blasted it and ran my taps in to clean the threads.nicholas bonham-carter said:Does anyone ever save the old fittings now?—NBC
- 110 Chimneys & Flues
- 979 Plumbing
- 387 Solar
- 17 Recall Announcements
