Steam replacement getting started
Dave0176
Dave0176 Posts: 1,184
edited July 2018 in Strictly Steam
Got a call from a HeatingHelp Wally in Sunset Park Brooklyn NY. Four family apartment tenement with two 2-1/2” mains. We’re going in with a Weil-McLain EG-75 and 4” header.
DL Mechanical LLC Heating, Cooling 732-882-2267 Specializing in Steam Heating
  • newagedawn
    newagedawn Posts: 585
    smart choice on the header, post some completed pics
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
  • How correctly was the old one sized?—NBC
  • Dave0176
    Header under construction. Doing some homework.
  • info43
    info43 Posts: 51
    edited July 2018
    Here is what the old one looked like
    The EDR came in at 698
  • SuperJ
    SuperJ Posts: 609
    edited August 2018
    HOLY FITTINGS BATMAN!!!
    Not much pipe in the header just a lot of close coupled fittings.
    1Matthias
  • JohnNY
    JohnNY Posts: 3,416
    edited August 2018
    Great work, as always, but you should probably take the address off this post. NYC inspectors are no longer playing around with gas installations.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    info43
  • Snowmelt
    Snowmelt Posts: 1,457
    Dave, I have a question on the equalizer after the drop and before the two take off, what is the length pipe you used and is there always a minimum length?
  • EzzyT
    EzzyT Posts: 1,380
    A beautiful install as always Dave
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Dave0176
  • AMservices
    AMservices Posts: 613
    Nice work!
    Can't wait for another steam job to come my way.
    It tough getting them when I'm biding against plumbers that are pricing a hack job.
    Double D
  • info43
    info43 Posts: 51
    @Dave0176 did a great job at a great price. Thank you Dave and Jim.
  • I’ve worked in DC on steam boilers for almost 12 years now and I’ve never seen a single install that pretty.
    In this area it’d probably have on riser, no header or an incorrectly piped header, and pressure set to 10psi. Inevitably I deal with this every winter here...
    Great lookikg work! Love it
    @AMservices I can sympathize. I’m not in charge of quoting jobs but I get to deal with hack installs all winter every year.
    Never stop learning.
  • Beautiful as always @Dave0176. And good for you to rip that entire old header out and start new.
    The results speak for themselves.
    New England SteamWorks
    newenglandsteamworks.com
  • Does anyone ever save the old fittings now?—NBC
    CLamb
  • Dave0176
    Not really, unless it’s in great shape and a rare fitting, for instance one job last year I saved a 2X2X3” cast iron bullhead tee. Took it home bead blasted it and ran my taps in to clean the threads.
