Too much cooling load on this HP?
from a video posted on FB
  • ChrisJ
    ChrisJ Member Posts: 17,380
    I thought that was a special defrost mode?
    Ironmankcopp
  • ratio
    ratio Member Posts: 4,237
    Nah, there's a cottonwood growing nearby, it's time to clean the coil.
    Jamie Hall Member Posts: 27,369
    But wouldn't that clean the coil?
    delta T
  • Ironman
    Ironman Member Posts: 7,903
    That's the latent heat of vaporization.
    Bob Boan
  • unclejohn
    unclejohn Member Posts: 1,833
    I actually had a customer call and say that smoke was coming out of the top of his HP in the dead of winter. I assured him that it was just steam from the defrost. He asked how does it defrost. I said by the hot gas. He said he did not have gas hooked up to his HP. I told him there is gas it his unit, he said natural gas I said no. Finally he says there are flames coming out of the top of my HP. Turns out the start thermister [I call them blasting caps now ] caught the unit on fire.
    Solid_Fuel_Man
  • GBart
    GBart Member Posts: 746
    No, that's the home of the blind guy, he got confused again when lighting his charcoal grill, the burgers are going to taste nasty.
    HVACNUT Member Posts: 7,444
    edited July 2018
    Put the phone away and grab the backpack dummy.
    And the disconnect is near the flames. Hope the breaker was off or tripped.
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    That's the new drop-in replacement for R22, comes in a tank that looks just like that 20 pounder from the grill...... cheap too!
