Replaced Burnham Boiler Banging and Clanging
2»
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    edited May 2018
    @Jamie Hall , @SlamDunk
    Forgiveness, I say yes, it's a word. Don Henley thinks so too. Listen at 1:39
    https://www.youtube.com/watch?v=tBJUTm9ez0g
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    SlamDunk
  • rbeck
    rbeck Member Posts: 56
    How many times can it be re-piped and still not be piped correctly. All those mains should also be piped back separately to the header.
    Dan Foley
