fittings for brass pipe
i think this is what i am dealing with
https://heatinghelp.com/systems-help-center/threaded-copper-tubing/0 -
Is it by any chance threaded? If so, it might be 3/8 NPT -- worth a try.Br. Jamie, osb
They do make adapter you can sweat onto brass pipe but I have never used them. Might be less of a problem to just replace it with copper or..... thread it0
I've used the brass adapters that slip over brass, and are sweated on, they work great, I have a couple in my fitting box that I haven't used in 25 years, you might find them at an old school Plumbing Supply store...
Thanks, Bob GagnonTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
1/2" sweat refrigeration fitting? Good flux and some silverbrite?0
They’re called TP fittings, threadless pipe. I worked for a company in the city for a while, we used them all the time.0
TP fittings as said above. They sell TP by cooper adapters, or you can manufacture one by drilling out the threads on copper x female adapter0
thanks everyone that is what i was looking for
is a tp adapter the same as a reamed adapter0 -
https://www.supplyhouse.com/Raven-LF12C12IPSRA-1-2-x-1-2-C-x-IPS-Reamed-Adapter-Lead-Free?gclid=EAIaIQobChMItPjNy8Kh2wIVQkOGCh3R2gVhEAQYBCABEgJ7SPD_BwE
is the above link the right adapter i should be looking for
it is not threaded it is copper looking pipe that is thick like brass that has soldered fittings0 -
Reamed adapters, hmmmm, never knew that, Lyle wins the internet today...To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 87K THE MAIN WALL
- 58 Biomass
- 112 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
