fittings for brass pipe
quack24
quack24 Member Posts: 74
does anyone know where to get a fitting that i can sweat onto 1/2 inch brass pipe ive seen them in use but never in a store or website
  • quack24
    Jamie Hall Member Posts: 23,327
    Is it by any chance threaded? If so, it might be 3/8 NPT -- worth a try.
    EBEBRATT-Ed Member Posts: 15,545
    They do make adapter you can sweat onto brass pipe but I have never used them. Might be less of a problem to just replace it with copper or..... thread it
  • Bob Gagnon plumbing and heating
    I've used the brass adapters that slip over brass, and are sweated on, they work great, I have a couple in my fitting box that I haven't used in 25 years, you might find them at an old school Plumbing Supply store...
    Thanks, Bob Gagnon
  • kcopp
    kcopp Member Posts: 4,432
    1/2" sweat refrigeration fitting? Good flux and some silverbrite?
  • Lyle {pheloa} Carter
    Lyle {pheloa} Carter Member Posts: 55
    The brass adapters Bobby's thinking about are called reamed adapters. Try Googleing them, I know Raven still manufactures them.
  • Danny Scully
    Danny Scully Member Posts: 1,425
    They’re called TP fittings, threadless pipe. I worked for a company in the city for a while, we used them all the time.
  • RomanP
    RomanP Member Posts: 102
    TP fittings as said above. They sell TP by cooper adapters, or you can manufacture one by drilling out the threads on copper x female adapter
  • quack24
    thanks everyone that is what i was looking for
    is a tp adapter the same as a reamed adapter
  • quack24
    https://www.supplyhouse.com/Raven-LF12C12IPSRA-1-2-x-1-2-C-x-IPS-Reamed-Adapter-Lead-Free?gclid=EAIaIQobChMItPjNy8Kh2wIVQkOGCh3R2gVhEAQYBCABEgJ7SPD_BwE
    is the above link the right adapter i should be looking for
    it is not threaded it is copper looking pipe that is thick like brass that has soldered fittings
    Reamed adapters, hmmmm, never knew that, Lyle wins the internet today...
