Solar pump stations, pre-ebay offer
hot_rod
Member Posts: 25,448
I have a few of these solar pump stations, new in original box. Grundfos 15-58 3 speed, 3/4" copper compression connections. Includes pump, safety group, air purger, check and iso valves S&R temperature gauge. Good for around 9 GPM, depending...
One version has a delta t controller installed. The other version, without controller does have a Grundfos VFS installed, reads flow and temperature, which wires directly to some controllers. Either can be run in variable speed function from most any solar controller. Wall bracket, insulation, and expansion tank bracket, check and flex included.
Certainly this could be used for any hydronic pumping application, it would not know or care if it were connected to solar or boiler energy
$120.00 or 150.00 with controller, plus shipping. Weighs about 20 lbs 12 X 16 X 10" box from 65742
Here is another with a 3X8" 30 plate heat exchanger. Would be great as a DHW module off a tank or boiler. Or to separate a glycol loop, non-barrier tube, etc.
$160.00Bob "hot rod" Rohr
Hot Rod, I am definitely interested in the unit with a Delta-T controller if it would work to maintain output temperature from a wood boiler. I was using a Taco VDT that quit this past spring. If you have a chance, give me a call at 573-230-2093. Joe in MO.0
I also have a pile of 12&24 VDC solar controllers, new in the box. It would require a power source and a RIB on the output to run on 120V $35.00
How is you system piped? The VS circulator needs to "inject" from the boiler loop to assure 100% temperature protection.
Can you call me tomorrow? I'd like to get one of each version of the pump station. Or, you can just go ahead and send them and call me if you need anything. All my info is still the same.
ThanksBob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 390 Solar
- 55 Water Quality
