Wiring replacement furnace circuit board
scotty27
Member Posts: 5
I was told by a plumber that I need a new circuit board on my Rheem Criterion gas furnace. They don't make the same boards anymore. I found one that says its a replacement, but it has one terminal missing. I have two yellow wires going to 2 different terminals on the original board, that are both labeled XFMR SEC. The replacement board only has one of these terminals. Would it work if i joined these two yellow wires and connected them both to the only terminal for XFMR SEC on the new board? Otherwise everything else matches up.
The proper replacement board has the proper terminals. Maybe, but a picture of both boards would help.
You could also look at the wiring diagram to see.
Of course your best option would've been to hire a pro, who would have done some proper troubleshooting, and most likely would've had a board on their truck, if that was indeed what was wrong.There was an error rendering this rich post.
Inside the furnace blower door is a label. It would have either an electrical ladder diagram or a electrical schematic or both.
I corrected this comment because the two yellow wires are a transformer secondaries. Do not connect them together.
It's the xfrmr secondary, sounds like. Both MUST land on the board, in one form or another.
I would think that the appropriate aftermarket/replacement board would have a wiring diagram that crosses the existing board to the new one. If you have to guess, you might be better off getting a pro.
I did hire a pro, and he came over and got one furnace fired up. He told me the other one needed a new board and didn't have one on his truck. He hasn't returned my phone calls since he came by. I figured I would at least get the new board before I called someone else. Anyway, I ordered a replacement board that matched up with the model number and the part number when i searched for it, but It isn't the same part number. It's supposed to replace the old board. I'll follow the wires to see if they connect. Thanks0
MODEL NUMBER RGDG - 10NBRJR
SERIAL NUMBER CY5D307 F2894 5761
OLD BOARD PART NUMBER 62-22694-11
NEW BOARD PART NUMBER 62-24268-03
CALL A PROFESSIONAL
THIS IS NOT FOR A HOMEOWNER0 -
I don't know why there are two wires, there is no AC.0
What is the make of the board? Is it an Electronic Fan Timer board or an Integrated Furnace Control Board. A picture would help. Honeywell and White Rodgers make Universal Replacement Boards but need to know who makes the board and the actual board number not part numbers.0
Are you positive that the new board is a replacement for 62-22694-11?
Ok, the 62-22694-11 has a XFMR sec and an XFMR com(mon). That board is powered by a transformer that is not a part of the circuit board. The two yellow wires should not touch together or you will blow the transformer internal fuse, and kiss it goodby. The two yellow wires are the secondary of the transformer. I don't think it will make much difference which yellow wire connect to which tab. If the transformer is marked com on the secondary then connect that wire to the com tab.
The 62-24268-03 board does have an XFMR common and sec tab. It has two tabs just like the old board. Look closely at the bottom where it say 24Vac XFMR-COM & SEC.
What would solve the problem is if the original board was available someplace.0
You can buy the original board on Ebay it you trust that source.
If your new board is a replacement for the old board, just use the new board. But, I wasn't able to verify that the new board is a direct replacement. You should verify.0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
