I'm Know You Get This Question A Lot, But . . .
alreu
Member Posts: 3
Hi Heating Help community--I sorted through a bunch of old posts relating to shutting off a radiator, but didn't run across any that looked quite like mine. Pictures attached below. Wondering which part I should be turning clockwise. Any help is appreciated, thanks!
It looks like you have a hot water system that someone repiped with pex. I would try to find a way to protect that piping.
There is not a shutoff in the picture. There may be a manifold with a valve in the mechanical room or cellar. Follow the red spaghetti and post more pictures."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
It looks like you may have regular pex on that system which will allow oxygen to enter your water and corrode your heating system0
There isn't a valve on that, so by those pictures you can't turn it off.
Are you a renter or owner?
Agree with above that is a garbage install.0 -
I'm a renter in New York, so the work was probably haphazardly done by a super at one time or another. I'll pass that info about the regular pex on to the super. Looks like I need access to the basement, I'll see what I can do. Thanks!0
In the meantime, I’ll give you the same advice I gave my mother (none of her shutoff valves work) - if it’s too hot in that room and you want the radiator off, drape a heavy blanket over it. Works wonders.Ford Master Technician, "Tinkerer of Terror"
Police & Fire Equipment Lead Mechanic, NW WI
Lover of Old Homes & Gravity Hot Water Systems1 -
If that room is overheating you could cover the radiator with a heavy quilt or rug. Drape it over the top. The rad should never exceed 160-180 degrees.0
This is probably your best option.JUGHNE said:If that room is overheating you could cover the radiator with a heavy quilt or rug. Drape it over the top. The rad should never exceed 160-180 degrees.
Albert Einstein0 -
Thanks! I've got just the quilt for the job. Last night really was murder—a blasting radiator, a wide open window, and nyc street noise.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
